Browse Forums General Discussion 1 Aug 30, 2022 2:16 am I am building my first house and the designer has made the bedroom windows on the top floor very narrow and high up on the wall, is there any way to avoid this or any potential solutions? I would really like to have normal windows I could easily look out of. Re: Second storey windows 2Aug 30, 2022 7:58 am Carlito I am building my first house and the designer has made the bedroom windows on the top floor very narrow and high up on the wall, is there any way to avoid this or any potential solutions? I would really like to have normal windows I could easily look out of. This is probably due to overlooking of a neighbours habitable rooms. You may not have a choice. Dark matter scientist, can breathe underwater, mind reader and can freeze matter just by willing it. Trust me, its in my sig. Re: Second storey windows 3Aug 30, 2022 8:08 am Depends on where you are and the approval process, but in NSW at least, whether you are going for CDC or DA, if the windows in the bedrooms are above 1.5m from floor, they should be OK. Having narrow windows at the top is probably more for your privacy than for your neighbours. Re: Second storey windows 4Aug 30, 2022 10:54 am Infinite-Justice Depends on where you are and the approval process, but in NSW at least, whether you are going for CDC or DA, if the windows in the bedrooms are above 1.5m from floor, they should be OK. Having narrow windows at the top is probably more for your privacy than for your neighbours. Do you know about Victoria's proces Re: Second storey windows 5Aug 30, 2022 11:35 am Infinite-Justice Having narrow windows at the top is probably more for your privacy than for your neighbours. um...what? Dark matter scientist, can breathe underwater, mind reader and can freeze matter just by willing it. Trust me, its in my sig. We were lucky in that our old house was so small (86 square metres) compared to the new house, they were able to take enough readings around the old backyard house before… 8 37387 Hi, We have a single story MacDonald Jones house, on a waffle pod slab with steel frame. Are we able to build a second story extension? Other info is we are 900mm from… 0 8574 We are building a second dwelling and are currently selecting window and door frames. We want to blend into the forest and also bring out the stone work and the fake wood… 0 16767 |
