Browse Forums General Discussion 1 Aug 29, 2022 12:49 pm Tiler Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Tiler has advised I can get away with no screeding on my alfresco slab before we tile as the ground is relatively level, covered by alfresco awning so doesn’t get a lot of water in the area at all. Can I get some advise if this is correct I can have no screeding and any risks if I don’t screed? He has advised I will need a primer for the top front porch also as I painted that with concrete paint. Just want to make sure if I don’t have any issues and lay the tiles directly into the concrete I won’t have issues he advised he uses a tile levelling system so it’s nice and level. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Alfresco tiles no screeding 2Aug 29, 2022 12:52 pm alannah Tiler Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Tiler has advised I can get away with no screeding on my alfresco slab before we tile as the ground is relatively level, covered by alfresco awning so doesn’t get a lot of water in the area at all. Can I get some advise if this is correct I can have no screeding and any risks if I don’t screed? He has advised I will need a primer for the top front porch also as I painted that with concrete paint. Just want to make sure if I don’t have any issues and lay the tiles directly into the concrete I won’t have issues he advised he uses a tile levelling system so it’s nice and level. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Tiles are 600x600 mm Is screeding required before you tile 3Aug 29, 2022 12:54 pm alannah alannah Tiler Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Tiler has advised I can get away with no screeding on my alfresco slab before we tile as the ground is relatively level, covered by alfresco awning so doesn’t get a lot of water in the area at all. Can I get some advise if this is correct I can have no screeding and any risks if I don’t screed? He has advised I will need a primer for the top front porch also as I painted that with concrete paint. Just want to make sure if I don’t have any issues and lay the tiles directly into the concrete I won’t have issues he advised he uses a tile levelling system so it’s nice and level. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Tiles are 600x600 mm Re: Alfresco tiles no screeding 4Aug 29, 2022 1:31 pm IMO you want some screed to actually create a bit of fall away from the house. While "it doesn't get a lot of water" due to cover, it will get rained on. And in the case of extreme weather (which we get more of these days) you don't want the water to be pooling in your alfresco. Just sounds like your tiler CBF doing the extra work Dark matter scientist, can breathe underwater, mind reader and can freeze matter just by willing it. Trust me, its in my sig. Re: Alfresco tiles no screeding 5Aug 29, 2022 1:35 pm Noname IMO you want some screed to actually create a bit of fall away from the house. While "it doesn't get a lot of water" due to cover, it will get rained on. And in the case of extreme weather (which we get more of these days) you don't want the water to be pooling in your alfresco. Just sounds like your tiler CBF doing the extra work Yes I see what your saying completely I’m nervous I just don’t want to use no screed and have issues with the integrity of the tiles or house but the only thing no screed will cause is pooling of water on the tiles shouldn’t be a major issue tho should it ? Re: Alfresco tiles no screeding 6Aug 29, 2022 1:55 pm alannah Noname IMO you want some screed to actually create a bit of fall away from the house. While "it doesn't get a lot of water" due to cover, it will get rained on. And in the case of extreme weather (which we get more of these days) you don't want the water to be pooling in your alfresco. Just sounds like your tiler CBF doing the extra work Yes I see what your saying completely I’m nervous I just don’t want to use no screed and have issues with the integrity of the tiles or house but the only thing no screed will cause is pooling of water on the tiles shouldn’t be a major issue tho should it ? the purpose of a screed is to level out any variations prior to laying tiles. The integrity of the tiles or the house wont be improved or diminished by a screed. basically you can lay straight on the concrete if you want (if it is level). If your tiles crack, they would have cracked regardless of whether screed was down or not. Ive mentioned the reason you want to put it down in the alfresco, but if you chose not to and then later change your mind, there a hell of a lot more work to do. My advice is get the screed down. Dark matter scientist, can breathe underwater, mind reader and can freeze matter just by willing it. Trust me, its in my sig. Re: Alfresco tiles no screeding 7Aug 29, 2022 2:33 pm It looks like there is a fall on the slab Hose test alfresco and if there is no water pooling you won't need screed Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Alfresco tiles no screeding 8Aug 29, 2022 3:57 pm Noname IMO you want some screed to actually create a bit of fall away from the house. While "it doesn't get a lot of water" due to cover, it will get rained on. And in the case of extreme weather (which we get more of these days) you don't want the water to be pooling in your alfresco. Just sounds like your tiler CBF doing the extra work Noname You are completely correct. Whilst it may not get water from the rain what happens when you need to clean the tiles with a hose or pressure washer? I would always screed as per your advice Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Alfresco tiles no screeding 10Sep 04, 2022 6:34 pm Bimbob Be sure the concrete is reinforced to avoid tiles cracking. Screed not required if slab has fall Hi yes the concrete is reinforces and very strong it is all mostly covered by awnings son doesn't get to much rain but it doesn't have fall either just flat Re: Alfresco tiles no screeding 11Sep 04, 2022 6:39 pm Agree with others - screed to ensure a fall away from your house. Do it once and do it properly. thanks. the above one is white Mat tiles and have gripness so going for this Mat tiles for both indoor and outdoor. Beaumont told it can be used in both indoor and… 2 1907 Hello! I've alfresco pitch of 3 degrees sitting just below the highlight window. Need advice on below: 1. Will the 3 degree pitch be ok to drain the rain water? The roof… 0 4286 Hi everyone, Newbie renovator here, after some advice for combining our family room in the picture and the alfresco and make a larger family room. There is a flush sill… 0 5164 |
