Browse Forums General Discussion 1 Aug 02, 2022 7:05 pm I might buy and rent out a property which has a long narrow metal balcony that is shared across 2 bedrooms without any support underneath (i.e. floating cantilever). The area could fit 6+ people, but is bit old/run-down so I'm worried it can't take the weight. Last thing I want is tenants having a party and it collapsing... Would a building inspector be able to advise on the load-bearing strength of a balcony? Or do I need a structural engineer for that? Thanks Example: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Building Inspection - Balcony Load/Strength? 2Aug 02, 2022 7:30 pm For structural advice you need structural engineer Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Any structural alteration to your home requires building permit. Before you get it you will have to supply plans with structural assessment, you will also be removing… 2 4140 First time building 2 storey home in NSW. Below Current plan have separate balcony. But thinking to do a multipurpose lounge with balcony (kind of sunroom) in first floor… 0 4790 Well you won't get cooked by the afternoon sun when sitting out on the balcony on a summers afternoon but you won't have much to look at besides the neighbours… 4 3766 |
