Browse Forums General Discussion 1 Jun 26, 2022 8:49 pm We build in Adelaide in 2018. This winter a number of internal doors seem to be catching. Could this be due to slab movement? Weather? It has been wetter this winter. I am a bit concerned about structural issues. No cracks internally or externally from what I can see. Thanks Re: Movement-Doors catching. 2Jun 26, 2022 9:08 pm Tighten the hinges on the door sometimes a few screws can become loose and cause the door to be out of alignment with the jamb. Re: Movement-Doors catching. 3Jun 26, 2022 9:10 pm Thanks : ) Just seems strange that 4 internal doors all have come loose together. Re: Movement-Doors catching. 4Jun 26, 2022 9:20 pm It might also just be regular movement (not necessarily slab movement), basically everything will expand and contract dependant on the weather, temperature, humidity etc. Re: Movement-Doors catching. 5Jun 27, 2022 9:18 am i wouldn't worry if you have no cracks. Often things aren't hung perfectly square, so the slightest movement and presto, your doors are catching. Most doors will have a fairly wide tolerance for adjusting hinges. There's some youtube videos on how to fix it. Try to avoid sanding down doors etc as a solution Dark matter scientist, can breathe underwater, mind reader and can freeze matter just by willing it. Trust me, its in my sig. Are they stumps or screw piles ? How much fill is there, is the site a class "P" ? A "H2" site is not supposed to have stumps it is supposed to have grid beams according… 1 7803 House movement is always a potential problem and there is a cause. Yes you should have it inspected by a competent and experienced building consultant 2 9194 ![]() 10 5414 |
