Browse Forums General Discussion 1 May 17, 2022 6:17 pm Hi, we have approved DA for a residential extension along with Architecture plans and about to start building. We want to make a slight adjustment to the plans, basically moving the location of a stairwell slightly inside the property. Nothing that the council had an issue with or gave any conditions about, i.e. assuming that if we had submit the plans originally with this change, they would have approved it just the same. My question is, does this have to go back to council, since the plans they approved will not fully resemble the final build? Or does the certifier just need to certify that any stairwell on the property meets the Aus building code (slope, headroom etc)? Understand its probably a grey area just trying to find an approximation of what can change from the original plans, if any, without needing council involvement again. Thanks! Re: Private certifier, variations? 2May 17, 2022 6:22 pm adjwhite86 Hi, we have approved DA for a residential extension along with Architecture plans and about to start building. We want to make a slight adjustment to the plans, basically moving the location of a stairwell slightly inside the property. Nothing that the council had an issue with or gave any conditions about, i.e. assuming that if we had submit the plans originally with this change, they would have approved it just the same. My question is, does this have to go back to council, since the plans they approved will not fully resemble the final build? Or does the certifier just need to certify that any stairwell on the property meets the Aus building code (slope, headroom etc)? Understand its probably a grey area just trying to find an approximation of what can change from the original plans, if any, without needing council involvement again. Thanks! if its an internal change then you just do it. Council only care about external changes Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Hi, does anyone have a clue how the Brisbane Development website work in terms of how uptodate the dates on it are (developmenti.brisbane.qld.gov.au). I transfered… 0 4719 Hi, I contracted a Builder to do a Garage to Bedroom + ensuite conversion (Class 1a), the Builder engaged the Certifier and Engineer and received BDA from the Certifier… 0 5225 It seems very clear to me that your contract states that a security account does NOT need to be established so the answer to the builder is NO. If in doubt find a contract… 1 8600 |
