Browse Forums General Discussion 1 Apr 16, 2022 12:56 pm hi everyone, i'm looking for some advice on what to do with 3 sets of internal doors. the Lounge, Theatre and Study. I'm close to contract signing for my build and am feeling a bit unsure about what's the best option between hinged and cavity sliding. one of my concerns with hinges is that my builder is not using 180 degree hinges so I feel like the doors will just be in the way when they're opened and they don't provide it as an option. for this reason, I am thinking if a CSD is better. alternatively, I am unsure if it is fairly easy to change the hinges to 180 degree hinges after handover in which case i could go down that route if its better than CSD. Also, they've put the study door in the middle of the wall, I am thinking if it will look nicer to make that also a double door (hinged or sliding) or to move it towards the end of the wall just before the partitioning between study and lounge. below is a pic of the floor plan with measurements Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Internal doors (CSD or Hinged) 2Apr 17, 2022 12:27 pm You need parliament hinges to clear architraves. I've only ever fitted 100mm brass ones, not sure if they come in chrome or black etc. They are a square corner hinge so you might have to fo a little chisel work and fettling but no problem to fit up. Depending on the style if your house you could go barn doors? Okay, then the choice is really about the build quality of the door itself which means the brand name. Sorry I can't recommend one or the other so best to rely on comments… 5 3256 Thanks. Yeh ideally that would have been good, but have progressed too far now. Hoping some well placed internal walls fixed up into the battens will provide some… 2 5402 Thank you alexp79 and gommeqld for your advice, that's very helpful, thanks 3 7921 |
