Browse Forums General Discussion Re: mice in walls and weep holes 2Apr 03, 2022 6:50 am When we had mice, I could mainly hear scratching sounds, never really popping. If the popping sounds happen when sun hits the home the cause would most likely be normal thermal expansion and contraction of timber/roof. Re: mice in walls and weep holes 4Apr 03, 2022 4:01 pm JoeyGO What was your solution to get rid of mice? I called in a Pest exterminator who came and found how they were getting in. He threw some poison pellets and some wax looking poison in the attic. A few weeks later there was a dead mouse under the house. He then came and got rid of the mouse, sealed up some brickwork with mortar and have never had a mouse back in 3 years. You are correct. Just read through all the ncc rules and 75mm is the minimum requirement for me. 4 11183 it depends on the natural ground level, if they excavated their boundary wall needed to be built as a retaining wall. If you filled, which sounds like the case then you… 1 7086 I know foam has been around since the 90's and CSR started manufacturing Hebel in 1989, so it's definitely possible 5 5457 |
