Browse Forums General Discussion 1 Mar 18, 2022 6:37 pm I will build a double storey new house and thinking if i shall get EV charging point provision in garage. I have applied 3 phase underground pit and i reckon switchboard should be inside my garage. Need require builder to have powerpoint on the wall for future EV charging or conduit wire or else? I just check Tesla which use wall connector for charging by directly connect wires. No idea how to tell builder for this provision. Can anyone share some knowledge on this? Thanks heaps. Re: Tesla or other EV charging point provision in garage 2Mar 18, 2022 7:41 pm ![]() I will build a double storey new house and thinking if i shall get EV charging point provision in garage. I have applied 3 phase underground pit and i reckon switchboard should be inside my garage. Need require builder to have powerpoint on the wall for future EV charging or conduit wire or else? I just check Tesla which use wall connector for charging by directly connect wires. No idea how to tell builder for this provision. Can anyone share some knowledge on this? Thanks heaps. You'll probably have an electric appointment where you can ask the electrician for a 32amps provision in the garage. We just did ours and it was $300 to add Re: Tesla or other EV charging point provision in garage 3Mar 18, 2022 8:11 pm ![]() ![]() I will build a double storey new house and thinking if i shall get EV charging point provision in garage. I have applied 3 phase underground pit and i reckon switchboard should be inside my garage. Need require builder to have powerpoint on the wall for future EV charging or conduit wire or else? I just check Tesla which use wall connector for charging by directly connect wires. No idea how to tell builder for this provision. Can anyone share some knowledge on this? Thanks heaps. You'll probably have an electric appointment where you can ask the electrician for a 32amps provision in the garage. We just did ours and it was $300 to add just wondering how the provision will be made? leave a socket on the wall? i have applied 63amp per phase to united energy, would be too big? Re: Tesla or other EV charging point provision in garage 4Mar 18, 2022 8:15 pm ![]() just wondering how the provision will be made? leave a socket on the wall? i have applied 63amp per phase to united energy, would be too big? No it will be a junction box Re: Tesla or other EV charging point provision in garage 5Mar 18, 2022 8:55 pm ![]() ![]() just wondering how the provision will be made? leave a socket on the wall? i have applied 63amp per phase to united energy, would be too big? No it will be a junction box thanks Re: Tesla or other EV charging point provision in garage 6Mar 18, 2022 10:40 pm You could always get a 3 phase output put on the wall. Then at a later date you can either replace it with the charger (hardwired) or have a 3 phase plug installed on the inlet of your charger and plug that into the 3 phase wall outlet. It would be nearer hardwired but using a 3 phase outlet would give you the option to change chargers without having to get a sparky in each time. You can plug and play. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Tesla or other EV charging point provision in garage 7Mar 19, 2022 12:21 am ![]() You could always get a 3 phase output put on the wall. Then at a later date you can either replace it with the charger (hardwired) or have a 3 phase plug installed on the inlet of your charger and plug that into the 3 phase wall outlet. It would be nearer hardwired but using a 3 phase outlet would give you the option to change chargers without having to get a sparky in each time. You can plug and play. Thanks for your reply. 3 phase output is called AC isolator? Re: Tesla or other EV charging point provision in garage 8Mar 19, 2022 12:21 am As the others said can run conduit or just run cable to a junction box. Good to read the specs for the charger per phase so the sparky knows what to run. I think I went for 6mm2 orange circular three phase. That should be OK to about 25A. Different cars have different locations too. Tesla is back left. You might want to run to two locations in the garage. Also run spare conduit for comms cables between charger and switchboard . Some smart car chargers measure the total household current usage and only charge if your solar system is in surplus and feeding back to the grid. It also pays to cable to a potential battery location while you are at it. Re: Tesla or other EV charging point provision in garage 9Mar 19, 2022 12:55 am ![]() As the others said can run conduit or just run cable to a junction box. Good to read the specs for the charger per phase so the sparky knows what to run. I think I went for 6mm2 orange circular three phase. That should be OK to about 25A. Different cars have different locations too. Tesla is back left. You might want to run to two locations in the garage. Also run spare conduit for comms cables between charger and switchboard . Some smart car chargers measure the total household current usage and only charge if your solar system is in surplus and feeding back to the grid. It also pays to cable to a potential battery location while you are at it. really helpful indeed. Just check Tesla wall connector allows 32A per phase maximum, will my 3 phase -63A per phase too big to cause overload? Re: Tesla or other EV charging point provision in garage 10Mar 19, 2022 1:17 am ![]() ![]() You could always get a 3 phase output put on the wall. Then at a later date you can either replace it with the charger (hardwired) or have a 3 phase plug installed on the inlet of your charger and plug that into the 3 phase wall outlet. It would be nearer hardwired but using a 3 phase outlet would give you the option to change chargers without having to get a sparky in each time. You can plug and play. Thanks for your reply. 3 phase output is called AC isolator? A 3 phase outlet is the 3 phase version of a powerpoint. Available as 415v 10 or 20 amp. You can just get one installed in the garage where you are thinking of putting the charger. Technically you can put the matching plug on any sort of charger and then plug that into the outlet. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Tesla or other EV charging point provision in garage 11Mar 19, 2022 2:03 pm ![]() ![]() As the others said can run conduit or just run cable to a junction box. Good to read the specs for the charger per phase so the sparky knows what to run. I think I went for 6mm2 orange circular three phase. That should be OK to about 25A. Different cars have different locations too. Tesla is back left. You might want to run to two locations in the garage. Also run spare conduit for comms cables between charger and switchboard . Some smart car chargers measure the total household current usage and only charge if your solar system is in surplus and feeding back to the grid. It also pays to cable to a potential battery location while you are at it. really helpful indeed. Just check Tesla wall connector allows 32A per phase maximum, will my 3 phase -63A per phase too big to cause overload? https://www.jcalc.net/maximum-demand-calculator-as3000 Car chargers are 100%, so the 32A per phase means you have 31A left per phase for everything else. You probably will set the charger to use a lower setting as you generally charge overnight using off peak or excess solar during the day. Either way there is no benefit in rapid charging. Look at the car you want, the charging times and then work out how fast you want to charge and therefore what size cable is needed. The 3 phase outlet is a good idea too. Re: Tesla or other EV charging point provision in garage 12Mar 19, 2022 5:52 pm ![]() ![]() ![]() You could always get a 3 phase output put on the wall. Then at a later date you can either replace it with the charger (hardwired) or have a 3 phase plug installed on the inlet of your charger and plug that into the 3 phase wall outlet. It would be nearer hardwired but using a 3 phase outlet would give you the option to change chargers without having to get a sparky in each time. You can plug and play. Thanks for your reply. 3 phase output is called AC isolator? A 3 phase outlet is the 3 phase version of a powerpoint. Available as 415v 10 or 20 amp. You can just get one installed in the garage where you are thinking of putting the charger. Technically you can put the matching plug on any sort of charger and then plug that into the outlet. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ get it, thanks! Re: Tesla or other EV charging point provision in garage 13Mar 19, 2022 5:53 pm ![]() ![]() ![]() As the others said can run conduit or just run cable to a junction box. Good to read the specs for the charger per phase so the sparky knows what to run. I think I went for 6mm2 orange circular three phase. That should be OK to about 25A. Different cars have different locations too. Tesla is back left. You might want to run to two locations in the garage. Also run spare conduit for comms cables between charger and switchboard . Some smart car chargers measure the total household current usage and only charge if your solar system is in surplus and feeding back to the grid. It also pays to cable to a potential battery location while you are at it. really helpful indeed. Just check Tesla wall connector allows 32A per phase maximum, will my 3 phase -63A per phase too big to cause overload? No the 63A will be the service fuse or maximum you can draw. A good sparky will do a maximum demand calculation using AS3000, for the whole installation. See this handy calculator: https://www.jcalc.net/maximum-demand-calculator-as3000 Car chargers are 100%, so the 32A per phase means you have 31A left per phase for everything else. You probably will set the charger to use a lower setting as you generally charge overnight using off peak or excess solar during the day. Either way there is no benefit in rapid charging. Look at the car you want, the charging times and then work out how fast you want to charge and therefore what size cable is needed. The 3 phase outlet is a good idea too. much appreciate! Re: Tesla or other EV charging point provision in garage 14Mar 22, 2022 1:31 pm If your meter box is on an external wall to the garage, I wouldn't stress about getting an outlet yet. You can fit one relatively easy at a later date. Just get the 3 phase to your house. Re: Tesla or other EV charging point provision in garage 15Mar 22, 2022 3:10 pm ![]() If your meter box is on an external wall to the garage, I wouldn't stress about getting an outlet yet. You can fit one relatively easy at a later date. Just get the 3 phase to your house. No, unfortunately the MB will not possible on garage side as my garage will be extent to the boundary. So i have to make a provision for future EV charging. Re: Tesla or other EV charging point provision in garage 16Mar 22, 2022 4:51 pm Hey chars. Definitely get a 3 phase 5 pin socket put on middle of garage wall as chippy suggests above. You can then connect wall chargers and remove later if required. We actually got one put on both walls for future 2 x EV household during our build, and wouldn't you know it my wife has bought an EV too. EV batteries are only going to get bigger so power needs in the garage will only increase. 3 phase is the way to go. Sometimes you will want to fast charge and single phase wont do it. Re: Tesla or other EV charging point provision in garage 17Sep 08, 2024 12:26 am ![]() ![]() You could always get a 3 phase output put on the wall. Then at a later date you can either replace it with the charger (hardwired) or have a 3 phase plug installed on the inlet of your charger and plug that into the 3 phase wall outlet. It would be nearer hardwired but using a 3 phase outlet would give you the option to change chargers without having to get a sparky in each time. You can plug and play. Thanks for your reply. 3 phase output is called AC isolator? The AC isolator is a different thing - just a switch to turn off the power to that circuit. The output mentioned about is the cable to feed the power. At which stage should I prepare for this, presumably post-handover at the landscaping design stage? But should the sparky provision for this when he does the rough in? I… 0 30244 The builder needs to provide all receipts related to provisional sums purchased up to every submitted progress claim. Anything above the stated provisional sums amount… 1 30753 Hi everyone, I'm currently building a new home with Mimosa Homes, and they expect to complete the lockup stage by early September. I anticipate the home will be handed… 0 2 |
