Browse Forums General Discussion 1 Feb 25, 2022 1:02 am I have a old brick veneer house in Melbourne, Today I noticed when rain comes, water coming out inside the brick wall just below the window sill(under floor level). Water is coming out near to the subfloor ventilation. ( can see in photos) Window is full size starting from floor level to ceiling. What can cause this leakage ? Thanks Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Water coming from brick veneer wall under the floor leve 2Feb 25, 2022 6:06 am I'm not an expert on these things - but I've seen water hit a roof tile - go up and under - then down until it finds an escape route. So I'd suggest checking the tiles directly above and around where the water is seen below. The tile(s) could be touching something - eg insulation - which might mean the rain water being "introduced" and running up inside the tile - then down the inside of the wall. Hope that makes sense - there is an official word for it. Is it - capillary action ? The ground around the building should slope away from the building as per NCC requirements to allow for stormwater drainage. Also check for pipes leaks, disconnections,… 2 4651 We used pro clima walls and roof. It's a high quality product (good vapour permeability and water resistance) and can withstand UV for a long period of time. Pro clima's… 10 22526 Interesting. You have great clearance to damp proof course all the way around which is rare with so many cowboy landscapers and concreters. Is there sufficient fall… 2 13589 |
