Browse Forums General Discussion 1 Feb 05, 2022 9:32 pm Hi, a noob question here to which I think I know the answer but need someone to confirm. I’m buying this lot 50. The developers are doing the sandstone retaining walls around the perimeter of the block. In the attached photo the honeycomb area is the building exclusion zone. My question for you all is how much is the slope on that honeycomb area starting from my neighbouring lot I.e want to know the slop from the neighbours retaining wall on the right to where my building pad (area outside the honeycombs) starts? Thanks for your help. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Land deposit: 17 Nov 16 Build contract: 17 Apr 17 Land settled: 16 June 17 BA: 23 June Slab: 3 Aug Frame: 21 Aug Enclosed: 10 Oct Fixing: 6 Nov PCI: 14 Dec Settlement: 21 Dec 17 https://forum.homeone.com.au/viewtopic.php?f=31&t=88597 https://forum.homeone.com.au/viewtopic.php?f=31&t=88597 the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 14358 A survey must’ve completed by a certified surveyor. This form part of every DA requirement 3 225261 Need advice on the backyard plan above. Should I excavate and cut all of the dirt to level with the house slab or semi-excavate as per photo above? Both left and right… 0 25123 |
