Browse Forums General Discussion 1 Jan 27, 2022 8:57 pm Hello All, I have a 1.9m opening for the front entrance door and would like to know what would be the best and ideal door width if I need to have sidelights at both ends? As per the image, I currently have 1.2m wide front door with 300mm sidelight on each side and 50mm separator on each side between the door and the sidelight. Thank you. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Ideal Entrance Door width for 1.9m wide opening 3Feb 02, 2022 2:30 pm yeah this is a wierd question. the plans already give you the answer. Dark matter scientist, can breathe underwater, mind reader and can freeze matter just by willing it. Trust me, its in my sig. Re: Ideal Entrance Door width for 1.9m wide opening 4Feb 02, 2022 5:45 pm We had an area large enough for 1200, but decided to go with 1020 in the end. We wanted a solid door, and so left room for the side lights, and also didn't want a pivot and were concerned 1200 would be too heavy for the kids. If you're happy with 1200, I'd stick with bigger. (When I say "we" decided to go with 1020, it was a compromise ) The warning is on the sticker on the door too. Second the aluminium powdercoat 6 18204 Thanks again for this information. If you do hear anything different, would be great to know 4 8256 Any structural alteration to your home requires building permit. Before you get it you will have to supply plans with structural assessment, you will also be removing… 2 4126 |
