Browse Forums General Discussion Re: Colorbond fencing how to angle 2Feb 09, 2022 12:08 am Hi TrickyD The fences I've installed have slightly different posts than yours in that they have an angle on the corners that give you enough flat area to put them edge to edge at a 45⁰ angle and then tec screw them on the inside. You then concrete the two posts in together. In your case I'd be digging out the final post and then re-concreting it back in with the new fence post once you have it all set up. The post's obviously ouch up the inside but are open on the back side. You could tec screw a plate across the top rails to keep it all together at the top. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Your house roof does not show rusting other than some surface rust on the flashings. In my opinion you dont need to replace or paint the roof other than treat surface rust… 1 10594 Hi all, Our boundary perimeter fences need replacing (3 sides). From everyone's experience, what would you install? Timber lapped and capped OR colorbond? Thank you. 0 3224 You should pressure clean your roof first and make sure the paint you buy also is anti mould. 4 21083 |
