Browse Forums General Discussion 1 Jan 13, 2022 9:55 pm I’m starting to look at options to knock down and rebuild. As much as I enjoy dreaming, I’m crashing back to reality. The block we have is 540 but it’s only about 12m wide. Given the required setbacks of 1.2m on both sides, that doesn’t leave a very wide block. Considering costs, I’m starting to look at spec home builders but don’t see many that would work on the block. Has anyone come across builders that work in narrow blocks? The length is about 42m so plenty of space to go back. Re: Spec Builders for 12m wide property 3Jan 14, 2022 9:12 am I came across Plantation Homes from Brisbane the other day. They have a section of designs to suit narrow blocks of 12m and 10m. I have two friends that built with them. That's why it prompted me to have a look at their website. I'm not sure how flexible your local council is on the setbacks. My local council requires 1m on one side and 3m on the other side. We submitted a plan with 1m on one side and 1.8m on the other side. It never got rejected or required any amendments. If financial allows, I would engage a draft person to draw up a plan and find a builder to build it. You can search a few floor plans or ideas online, show those to your draft person. They can incorporate those ideas into a floor plan to suit your land. Even looking at those floor plans from Plantation Homes, they are only 23m long. If it allows, wouldn't you want to build as much as you can? You would be able to maximise the usage of your land using a customised floor plan. My local council has 40% site coverage requirement. I wouldn't be able to achieve that if I used a volume builder's floor plan. Re: Spec Builders for 12m wide property 4Jan 14, 2022 10:22 am Jason526 I came across Plantation Homes from Brisbane the other day. They have a section of designs to suit narrow blocks of 12m and 10m. I have two friends that built with them. That's why it prompted me to have a look at their website. I'm not sure how flexible your local council is on the setbacks. My local council requires 1m on one side and 3m on the other side. We submitted a plan with 1m on one side and 1.8m on the other side. It never got rejected or required any amendments. If financial allows, I would engage a draft person to draw up a plan and find a builder to build it. You can search a few floor plans or ideas online, show those to your draft person. They can incorporate those ideas into a floor plan to suit your land. Even looking at those floor plans from Plantation Homes, they are only 23m long. If it allows, wouldn't you want to build as much as you can? You would be able to maximise the usage of your land using a customised floor plan. My local council has 40% site coverage requirement. I wouldn't be able to achieve that if I used a volume builder's floor plan. Our council has 1.3 side setbacks on each which puts the building width at about 9.7. We can build up to 55% which would put the buildable area around 230m2. Right now I’m putting high level cost estimates to see what’s possible. I have grand visions of funds weren’t an issue (cmon NFTs!!), but we’ll need to come back to reality a bit. Re: Spec Builders for 12m wide property 5Jan 14, 2022 10:59 am FinallyFoundAHome Jason526 I came across Plantation Homes from Brisbane the other day. They have a section of designs to suit narrow blocks of 12m and 10m. I have two friends that built with them. That's why it prompted me to have a look at their website. I'm not sure how flexible your local council is on the setbacks. My local council requires 1m on one side and 3m on the other side. We submitted a plan with 1m on one side and 1.8m on the other side. It never got rejected or required any amendments. If financial allows, I would engage a draft person to draw up a plan and find a builder to build it. You can search a few floor plans or ideas online, show those to your draft person. They can incorporate those ideas into a floor plan to suit your land. Even looking at those floor plans from Plantation Homes, they are only 23m long. If it allows, wouldn't you want to build as much as you can? You would be able to maximise the usage of your land using a customised floor plan. My local council has 40% site coverage requirement. I wouldn't be able to achieve that if I used a volume builder's floor plan. Thanks for calling out that builder. We sunk more into the purchase and are quickly seeing that we’ll outgrow the current house quickly. While we are considering a custom home, there is a big cost savings using a spec builder. Our council has 1.3 side setbacks on each which puts the building width at about 9.7. We can build up to 55% which would put the buildable area around 230m2. Right now I’m putting high level cost estimates to see what’s possible. I have grand visions of funds weren’t an issue (cmon NFTs!!), but we’ll need to come back to reality a bit. 55% of your block 540m2 is 290m2. 55% is looking at your whole block, not after setbacks. So roughly speaking, if you are allowed to have site coverage 290m2 with a 10m wide house, you could potentially have a 29m long house. That's better than a 23m long house in my opinion. Volume builders allow some alternations to their plans, but you gain some you lose some. Re: Spec Builders for 12m wide property 6Jan 14, 2022 11:43 am NSW CDC guidelines allow 55% of land size which would be 290. Council is 55% of buidable area which does include setback requirements hence the smaller build area. Hi, Seeking volume or semi-custom builder in victoria(east), which have existing double story wide floor plans. Seeking 18-20m wide homes with depth of 12-15m long. Or… 0 25171 that’s in the wall, it’s more about the trap and basin location within the cabinet. If the basin inset or the trap is sideways there is less space within the vanity… 4 1522 |
