Water feed to house
Can anyone tell me what the standard is regarding location of pipe for water feed to house? I'm a little confused... I thought it would be in the slab not an obvious pipe through the brickwork.
I'm in NSW - keen if someone can point me to any docos or pictures that show what the standard is?
3
if it's the look that you're not happy with, the easiest option would probably be to spray paint it all into the same color as the walls so it blends in. there might not…
12/12/2023
6
Thanks for the advice mate. I'm on it.
20/12/2023
4
Thanks for the photos. You need to know whether the inflow or the overflow pipe is leaking and this is a simple process of elimination. INFLOW: The vertical riser…
