Browse Forums General Discussion Re: Site cut issue - retaining wall & stepped backyard 3Dec 08, 2021 8:26 pm Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog thanks chippy! here is the back of the wall which has not been backfilled yet. Here is the same back of the wall taken from the other end, behind the steps. As you… 5 12414 PM me your email. I have a build excavation calculator you can use based on your plans to double check what your builder is telling you. Cheers Simeon 1 26254 *possibbly damaged pipe joint. Worth an inspection, but lets not assume. 4 10039 |
