Browse Forums General Discussion Re: Water leak/stain 2Nov 29, 2021 6:28 pm Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Water leak/stain 3Nov 29, 2021 6:36 pm Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Water leak/stain 4Nov 29, 2021 6:42 pm SejaeD Livo4Life Hi guys, first time poster long time reader In the process of building atm, and we have just recently finished the guttering on the garage roof. We've had numerous days of rain in Sydney over the last couple weeks, however it's been relatively dry today. The question I have is with regards to the garage side wall. It was obviously wet during the down pour, however it's dried up now But for some reason I've got a large water stain on the brickwork (see pik). No fisable water leaks on the insed of the garage and under the sheeting. Scratching my head as to what it could be. The side capping does have a slight bend to the middle of it (see pik) Any ideas or help would be great Cheers Maz Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Maz Looks like the downpipe isn't connected yet and my guess is the water is running back along the capping to a low spot then down the wall. But that is a really strange detail. Trying to figure out why they have designed the gutter/flashing detail that way. It's as though the bricks have finished a couple of courses low and they have had to cover the gap with the colorbond capping. Hard to tell Simeon G'day Simeon With regards to the guttering, I'm on zero boundary so there was no choice with a trading overhanging gutter system, unless the framing was modified prior to gutter fittment and unfortunately we didn't quite get to achieve that until it was too late lol Re: Water leak/stain 5Nov 29, 2021 6:44 pm chippy It looks like the pop from the gutter doesn't have a downpipe fitted yet so any water runs straight on to the flashing below and then as you have noticed were the wet mark is is the low point of the flashing, so the water runs down the wall at that point. You probably have some water in that upper gutter that has slowly trickled out, possibly even some condensation from overnight. Once the downpipe is connected it will be fine. Cheers chippy You would be correct in saying that the piping as not been completed and in addition a splitter hasnt been completed for the top roof piping as yet as well. Hoping once this is done it fixes the issue Cheers Re: Water leak/stain 6Nov 29, 2021 6:44 pm Livo4Life SejaeD Livo4Life Hi guys, first time poster long time reader In the process of building atm, and we have just recently finished the guttering on the garage roof. We've had numerous days of rain in Sydney over the last couple weeks, however it's been relatively dry today. The question I have is with regards to the garage side wall. It was obviously wet during the down pour, however it's dried up now But for some reason I've got a large water stain on the brickwork (see pik). No fisable water leaks on the insed of the garage and under the sheeting. Scratching my head as to what it could be. The side capping does have a slight bend to the middle of it (see pik) Any ideas or help would be great Cheers Maz Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Maz Looks like the downpipe isn't connected yet and my guess is the water is running back along the capping to a low spot then down the wall. But that is a really strange detail. Trying to figure out why they have designed the gutter/flashing detail that way. It's as though the bricks have finished a couple of courses low and they have had to cover the gap with the colorbond capping. Hard to tell Simeon G'day Simeon With regards to the guttering, I'm on zero boundary so there was no choice with a trading overhanging gutter system, unless the framing was modified prior to gutter fittment and unfortunately we didn't quite get to achieve that until it was too late lol thanks for clarifying we don't do any zero lot work so it is a detail I haven't seen. Great to hear it was intentional! Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Water leak/stain 7Nov 29, 2021 6:52 pm SejaeD Livo4Life Livo4Life Hi guys, first time poster long time reader In the process of building atm, and we have just recently finished the guttering on the garage roof. We've had numerous days of rain in Sydney over the last couple weeks, however it's been relatively dry today. The question I have is with regards to the garage side wall. It was obviously wet during the down pour, however it's dried up now But for some reason I've got a large water stain on the brickwork (see pik). No fisable water leaks on the insed of the garage and under the sheeting. Scratching my head as to what it could be. The side capping does have a slight bend to the middle of it (see pik) Any ideas or help would be great Cheers Maz Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 😅😅 Cheers mate Tbf I was hoping it was going to be a box gutter option (aesthetically more appealing I guess) but maybe it's a silver lining to have it this way as iver heard box gutters can be susceptible to leaks If you make sure all taps inside and out are turned off, what does the water meter show if you leave it for a while. 2 20229 Hi all, I am hoping someone has some ideas as to what is causing my bathroom leak. The leaking appears to mainly happen when we turn the sink basins on. It takes a while… 0 5075 DIY, Home Maintenance & Repair Are you doing this with a building permit? Conversion of a non habitable room into a habitable room requires building permit. 3 17311 |
