Browse Forums General Discussion 1 Nov 17, 2021 8:18 pm Hi guys my house's practical completion is next week, could you please help me with identifying the below things I found during my inspection, may I please get your professional opinion on whether these are indeed issues that need to be addressed or not: 1. The toilet for first floor bathroom is installed at a awkward position, it is supposed to be in the middle point between the bathtub and the cabinet according to the joinery drawing (attached), however the right edge of the toilet is now just too close to the bathtub (around 13cm) which I think it will create many issues when using it (hardly to spread legs) and based on the measurement drawing the left edge of the toilet to the cabinet should be 700+1776-1200-252.2-750=273.8mm but now the distance is much more than that. This bathroom is the largest one for my house and I am getting such a narrow space for my toilet which I believe is not acceptable and satisfactory workmanship. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 2. The 3 LED lights on the ground floor's hallway are not lining up hence is not matching with the electrical plan (attached) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Spoke to my site manager, he said they won't do anything with it as this is not defect and are not issues from his opinion, if I am asking the toilet and light point position to be changed, I will need to be responsible for all the cost and delay. May I know what should I do now Building Standards; Getting It Right! Hi, yes, we have the report. The builder has rectified the items on the report and we’re moving forward with the build. Thanks for reaching out 2 2255 1) I had requested R6 ceiling insualtion batts, however I noticed that on some areas there are huge gaps which will allow hot air to sweep in, and also noticed black/grey… 0 3597 My door tends to rub against the frame during winter and I'm looking to fix it so it closes smoothly. Looking online on Youtube I'm seeing methods to fix the alignment and… 0 692 |
