Hi
Can I extend the 100mm sewer inspection shaft on my property up through new shed slab nsw?
Thanks
Browse Forums General Discussion Re: Sewer inspection shaft 2Nov 14, 2021 7:33 pm you would be better off leaving it where it is and provide inspection hatch in the shed floor Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Sewer inspection shaft 4Nov 14, 2021 7:47 pm Br1 Thanks Was enquiring as to whether or not it is permitted That is a question for a licensed plumber in your area. If you modify sewer inspection it should be done by a licensed plumber I was simply giving you a practical solution I hope you are not mistaking gully trap overflow for sewer inspection pipe Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Hi, I have this sewer inspection point sitting in an odd spot in the rear of my yard: https://imgur.com/ghLI98q What I'd like to do is put a firepit in that corner of… 0 6520 Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 11753 4 5105 |
