Browse Forums General Discussion 1 Nov 04, 2021 4:02 pm i have a problem with a plumber, the matter going to the court , he connect pvc pipes from two down pipe of left side of house to the kerb in the street . and i asked him to put also inspection door on each side of down pipe so i can check for blockage and he did ,also he connected down pipe from pergola in junction with other pipe to street . after big rain when i checked i saw the water still in the pvc pipe and when i open the inspector lead , the water like river going to back of house that mean the-water not only going to street going back flow to down pipes of house and the fall down from gutter down . as result of not levelling the pipe also the slop of land to back of house not to street . he quickly telling fib that he used charged system .how can i prove to the court that he simply pipe to street ,now he down mistake and call it charge system . i need to prove to court . thank for your help Re: charege line system plumbing 2Nov 04, 2021 4:44 pm mina mp i have a problem with a plumber, the matter going to the court , he connect pvc pipes from two down pipe of left side of house to the kerb in the street . and i asked him to put also inspection door on each side of down pipe so i can check for blockage and he did ,also he connected down pipe from pergola in junction with other pipe to street . after big rain when i checked i saw the water still in the pvc pipe and when i open the inspector lead , the water like river going to back of house that mean the-water not only going to street going back flow to down pipes of house and the fall down from gutter down . as result of not levelling the pipe also the slop of land to back of house not to street . he quickly telling fib that he used charged system .how can i prove to the court that he simply pipe to street ,now he down mistake and call it charge system . i need to prove to court . thank for your help you can put some die ( food colouring) in the water and then film it when it comes out in the street Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. 4 10822 Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 11759 In WA zero lot is actually zero lot. We build 10mm in from the boundary. My house and my neighbours house have garages that sit only 20mm apart. When I had our roof done… 3 7067 |
