Browse Forums General Discussion Re: plumbing standards question 2Oct 05, 2021 7:37 pm This system has some great water and energy savings. Not sure about BCA but found this article in Plumbing Connection. https://plumbingconnection.com.au/bringing-the-heat-with-manifold-systems/ Re: plumbing standards question 3Oct 05, 2021 7:42 pm Not just that, but also reliability when it gets to water leaks (there is no/zero T-connections), equalisation of the water pressure for all the water connections, easy to add water purifying filters, etc. Building Standards; Getting It Right! Don't think they are designed for double brick. WA has a particular way of building and unfortunately that's the way a large amount of sills are finished. 3 7203 I believe this is correct. From the picture you can see the power was put in last so the electrician knew where the water was. Really it's a common sense issue more… 4 5236 2 8821 |
