Browse Forums General Discussion 1 Oct 02, 2021 12:00 pm Hi, we have water pooling on our wooden stairs every time it rains. Any suggestions on what we can do to stop the water pooling? Its often a lot worse than what you can see in the picture here. I was thinking of sanding the treads slightly to allow for a couple of mm fall. Keen on whether this is the best option, or if there are other options. Thanks Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ This certainly doesn't look good. I would be engaging with an independent inspector to have a look at this. As for the unscheduled site visits, most builders are quite… 1 28290 Need more photos from around the house including your gutters. We have had 3 of the wettest years in a row for some time so that wouldn't be helping 3 6940 Following these simple steps will help you mitigate unwanted costs, have your expectations met and give… 0 4529 |
