Browse Forums General Discussion Hi, Currently building, we are on a sloping block so we have from floor level to the roof in axon cladding. Below floor level to the ground I want to put brick facings /… 0 2736 DIY, Home Maintenance & Repair All my inside walls are Fibre Cement & House has Steel frames... Tricky when one wants to hang pictures or do Wainscoating Paneling up the hallway. Those little nail… 0 1813 Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 3200 |
