Browse Forums General Discussion 1 Sep 20, 2021 9:32 am Hi Guys, Hope all is well! I have recieved this lighting schedule and would like some feedback on the design. The design seems to be downlight heavy in most areas, which we would like to steer away from. The home is a post war home and we think that the downlights may clash with the layout. Let me know please. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 28812 I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 8812 What? It's a lighting question, the control joint is only needed at 12m centres, a bulkhead or change of direction will suffice as a 'break' in the ceiling, just make… 8 8570 |
