Browse Forums General Discussion 1 Sep 12, 2021 6:45 pm I'm looking at installing anticon 60 insulation in the walls of a shed that I'll be building on the next few weeks. Main reason is it won't require internal cladding and is relatively inexpensive. The shed has steel z purlins and will be clad with monoclad tin. Can anyone tell me what the compressed thickness is of anticon 60? I'm thinking the 16mm wall screws provided will be too short... any tips from people who might have attempted this are welcome! One corner of my shed slab will be directly over a 1400mm diameter concrete soakwell. Is it feasible to fill the soakwell with concrete then lay the shed slab over the… 0 11292 Hi there, We are currently building a veranda off the side of an existing Olympic shed. Does anyone have experience with fixing through corrugated wall sheets. I am… 0 26115 When I worked on leveling my shed, I found that using adjustable base plates or shims was a pretty effective way to stabilize it. Another approach I tried was building a… 1 18692 ![]() |
