Browse Forums General Discussion 1 Sep 11, 2021 4:29 pm What happened: - Ordered exposed aggregate driveway, but some part of it is under-exposed. - I, being stupid, decided to use power drill with wire-brush wheel to remove the sand stuck on top of that area. I saw dark particles being produced by abrasion actions of the wire-brush, and I used running water to rinse it away. - As a result, area I worked on look like DARK STAIN. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ . What happened was that some light coloured pebbles had been stained during the abrasive process using metal wire-brush wheel. Detailed photos: - area I didn't touch (normal area): Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ - area I messed up (stained area): Pebble of greyish colour was pure-white before. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Question: How to make the dark stain on concrete driveway less obvious? Re: How to correct colour insistency on Exposed Driveway? 2Sep 11, 2021 7:19 pm So many questions but I suppose the only one that is important is, has it been sealed yet or is this freshly laid. The best way to deal with under exposure is sand blasting. It may fix the area you have polished with the wire brush. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: How to correct colour insistency on Exposed Driveway? 3Sep 11, 2021 7:45 pm Hi Chippy, It has been sealed. And there is no more under-exposed area anymore, as they had been dealt with my wire brush wheels. My guess is to find a way to brighten white pebbles in the affected area, which were stained by the wire brush wheels. Brake and Parts cleaner can potentially cause damage to an exposed aggregate driveway due to its chemical composition, which… 2 11030 Building Standards; Getting It Right! Hi all, My neighbour has built his 15m long garage on our boundary. It was agreed as part of the planning permit that the wall must be in exposed recycled brick. For some… 0 7239 Last year I had a gas leak at my house. 3 days later, I have about 1 sqm of my exposed aggregate paving broken up. I am not sure how to go about getting it repaired… 0 8122 |
