Hi,all
I'm building a 5x3m garden studio and will be using primarily 90x45mm timber for the frame. What screws would you recommend for a) putting the frame itself together, and b) to screw the frame to the floor?
Thanks in advance.
Browse Forums General Discussion 1 Sep 09, 2021 9:33 am Hi,all I'm building a 5x3m garden studio and will be using primarily 90x45mm timber for the frame. What screws would you recommend for a) putting the frame itself together, and b) to screw the frame to the floor? Thanks in advance. Sam There is a much stronger glue than liquid nails. It's called T Rex and will stick your timber to the concrete. Cheers Simeon 1 1557 This is 100% true. You can not hang anything on steel frames. very frustrating 8 8062 |
