Browse Forums General Discussion Re: Shiplap cladding search 2Sep 29, 2021 3:00 pm That's an old profile and something similar used to be common here is Sydney too. You may have to get a timber company to do a special run for you. Sometimes you can be lucky to get a profile pretty close to what you are after and by using a router to run another rounding over mould, ovolo or similar you can get a near perfect match. Been there done that on a couple of renos. We have used this method on a lot of architraves and skirting too that had to match existing. Getting a carpenter to do this on site can sometimes work out a lot cheaper. Stewie Re: Shiplap cladding search 3Sep 29, 2021 3:11 pm Thanks Stewie, Great advice. I have one supplier with a profile 20mm higher and was already sorting through my router bits (thinking along those lines). I’m still hoping I can find a timber company that will match it exactly, saving me the extra effort. Re my second point – yes exactly. And often it may take additional time if the manufacturer recommends no more than X meters… 3 6286 Hi, Currently building, we are on a sloping block so we have from floor level to the roof in axon cladding. Below floor level to the ground I want to put brick facings /… 0 4870 The most definitive answer to your question James is this taken from the James Hardie Axon Cladding Installation Guide - i just happen to have it… 5 4103 |
