Browse Forums General Discussion 1 Sep 04, 2021 9:52 pm Hi, Wondering if anyone knows what this style/name of roof in a bathroom is? do they usually contain asbestos or? Thanks https://ibb.co/2K4Ftkf https://ibb.co/QKTkPQ2 https://ibb.co/92qL3Qb Re: What is this roof in bathroom? 2Sep 05, 2021 11:14 am It looks like perforated Caneite judging by the texture, are there any joining strips? Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: What is this roof in bathroom? 4Sep 05, 2021 5:24 pm building-expert It looks like perforated canine judging by the texture, are there any joining strips? Thanks so much for replying. I don't think there is any joining strips. Its in basically one large piece/sheet in bathroom ceiling. Are these usually hard to remove and to replace with plasterboard? Is perforated canine usually asbestos? Re: What is this roof in bathroom? 5Sep 05, 2021 6:02 pm loz1991 building-expert It looks like perforated canine judging by the texture, are there any joining strips? Thanks so much for replying. I don't think there is any joining strips. Its in basically one large piece/sheet in bathroom ceiling. Are these usually hard to remove and to replace with plasterboard? Is perforated canine usually asbestos? That should have read Caneite, a compressed sugarcane straw. If there are no joints then probably it is not Caneite. Removal of light fitting will expose material for identification. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: What is this roof in bathroom? 6Sep 05, 2021 7:11 pm In the first picture (link) you can see the joint. They've used a vee joint so I'd say it's either the canite or masonite. Both are timber fibre base so no asbestos to worry about. Canite will be roughly 10-12mm thick and quite soft, masonite is thin (around 5-6mm) and is fairly solid and hard and is a dark brown colour. I've never seen an asbestos sheet with holes like that and there'd normally be a joint strip or batten on the joints. I'm pretty certain you'll be right to remove and replace. Like building expert said, once you remove your light fitting you'll know. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: What is this roof in bathroom? 7Sep 05, 2021 8:21 pm An option may be to leave ceiling material in place and glue and screw plasterboard under and then finish off and paint. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: What is this roof in bathroom? 10Sep 08, 2021 4:14 pm Thanks for all your replies, useful information! I found an old picture of when repairs being done to a section. See below https://ibb.co/RBT442v Re: What is this roof in bathroom? 11Sep 08, 2021 5:08 pm It looks thin and the colour of masonite. Either way it doesn't contain asbestos so you can do as you please with it. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Render your bathroom walls, two opinions versus the one, makes you wonder. 3 6057 Hi Geoff Install Puddle Flange prior to any screed. Puddle flange needs to be flush with the surface so you may need to grind away the surface to achieve this. Also as… 2 8367 Hello It is good to have a planned bathroom reno to suit your budget and design, living for 10 years I think you need a bathtub 4 10371 |
