Browse Forums General Discussion 1 Aug 31, 2021 7:39 pm Gday all, I am currently building a decking at the back and am stuck with what to do around the window sill (see photo). Finished level of the deck will be at the floor level of the house, although the window sill is slightly higher and the sill bricks are getting in the way of the joist/ decking boards. One option is to cut the brick back and have the deck flush with the wall. The second option would be to remove the bricks and have the joist extending into the the cavity, although unsure about how to flash this, would I best to get a sill tray made up for the cavity? House doesn't have any eaves and windows cop a fair bit of weather. Any suggestions would be appreciated, Cheers Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Window sill removal & flashing for decking 2Aug 31, 2021 11:34 pm You're over thinking it. Butt the joists up to where they can go to and Cut the board to fit the bricks. Dark matter scientist, can breathe underwater, mind reader and can freeze matter just by willing it. Trust me, its in my sig. Building Standards; Getting It Right! There doesn't look to be any rebate in the slab to prevent water from scooting under the window. AS4654 is the Australian standard to look at/refer to. They have… 1 10128 AFAIK, flashing is a minimum standard. Out of curiosity is your window glass stamped with AS requirements in any of the corners of each pane? Im almost certan if theyre… 2 6271 Hi, as per the subject. Does anyone have any recommendations for the best value decking oil (Bunning is close to where I live) for a treated pine deck? Thanks 0 10940 |
