Identifying the level of Datum of the finished ceiling heigh
AHD is 58.41m (Metres)
generally the FFL is 0c (0mm) , Brickwork 28c (2400mm) , etc
we use brick gauges in Perth HTH
I'm a student. and is extremely confused.
they given the ceiling height and RL to identify the ceiling height from Datum.
Your Ground floor is 58.60m RL
If you add your 2700mm ceiling height and your 330mm upper floor depth (3.03m) it gives you the 61.63 which is your upstairs RL.
Your garage is at an RL of 58.41 so it's 190mm below your ground floor level.
So Do I add 2700 + 190mm to find the GROund floor ceiling height from level of datum. ?
Your ceiling should be at 58.6+2.7 - 26 mm for plasterboard and furring channels.
so if you add 58.6+2.7 = 61.30m from AHD (datum) point?
Yes
you are a legend! thank you
13
interesting situation what happened after builder issued final invoice? did you list as defect or not does the building surveyor have any responsibility? ie. issuing…
13/01/2024
Hi all, My neighbour has built his 15m long garage on our boundary. It was agreed as part of the planning permit that the wall must be in exposed recycled brick. For some…
15/02/2024
Hi, I contracted a Builder to do a Garage to Bedroom + ensuite conversion (Class 1a), the Builder engaged the Certifier and Engineer and received BDA from the Certifier…
