Browse Forums General Discussion 1 Aug 07, 2021 5:10 pm Hi guys, just joined this forum. I have a 800 kg pool table with 4 legs. I have just moved house and only option is to install table into shed with wooden floors, covered bye chipboard. My question is, will I have to dig holes filled with concrete or will pavers be ok to take the weight of around 200 kg each leg? The soil around shed is very Clay type soil. Would appreciate any feedback. I would probably render it and then paint it as per your other advice, or gyrpock over the top. 1 3335 To put anything over slate you will need to put self level compound over the entire area as slate various in thickness and is very un even. To install most types of… 1 389 just pull up the slate. If you go over the top, your tiles would not have an even surface to be glued to. Im no tiler, but i can imagine a couple of things being an issue… 1 326 |
