Browse Forums General Discussion Re: In Home one forums do we have place to leave reviews 2Aug 03, 2021 3:35 pm Homeone is not a product review site but if your query is in reference to your other thread that discusses your internal cracking, then you can post on-topic comments there. I do however tend to agree with the opinions you have received from other forum members that the builder is not at fault if the slab has heave caused by the flow of water off the path not entering a drain. How wide are the cracks? viewtopic.php?f=1&t=99834 The other forum members may also have been "delicately kind" in not mentioning that the builder and his engineer lacked knowledge about the required slope away from the foundations when they referred to the inaccurate CSIRO guide but the real issue is the water run off from the sloped path pooling along the sloped path's edge due to there being no drainage. During wind driven rain, this concentration of water off the wall and path could be considerable. If you make any comments against the builder that blames him for the cracking without having proof that any heave is his fault, you will open yourself to possible defamation proceedings if the builder is named or otherwise identifiable. To establish a case against the builder, you would need structural and geotechnical engineer reports that show the cracking is abnormal and not caused by sub surface hydraulic pressure variance (if any) attributable to water pooling along the path's edge. . Have the slab levels been taken and what is the soil classification? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. We are looking to do a KDR with fairhaven homes, Have seen plenty of good reviews about them pre construction and plenty of negative reviews about them during contruction… 0 18147 Hi starting the process of looking around for Dual Occ builders. Looking to build a home shared with family either as a duplex or front back. Has anyone done any recent… 0 2335 Old Home Restoration / Renovation I cannot find a review for the Reblocker I am getting a quote from. Am I doing something wrong, or are numbers of reblockers who hold VBA registration not reviewed on your… 0 2487 |
