Browse Forums General Discussion 1 Jul 18, 2021 11:10 am Hi everyone, hoping to get some advice prior to starting this process - i have no idea of the implications to myself so want to make sure I go in with my eyes open. I have bought a property in Kingston council VIC, that has a huge tree in the front corner of the property. This is easily a significant tree so requires a permit for removal. This tree is hard on the fence line and is pushing forward the brick front fence, which is leaning towards the footpath. This is a hazard and needs to be actioned. The kicker is there is also a stormwater easement (E-1) that runs through my property and this tree is over that. I have some suspicion that the tree has damaged the easement based on the grass growth on the nature strip. So my questions are as follows: - is the damage to front fence a reason to remove a significant tree? Or would I be told to just remove the current fence and build around it so to speak. - as the tree is over an easement on private property, is the cost of the removal paid for by myself or the council? - in the event this tree has damaged the stormwater pipes, am I liable for the cost of fixing this? I have owned the property for less than a year and this tree would be decades old. Thanks in advance to whoever may be able to help with some of the above. Not sure if relevant but I am one of two units on the block which was subdivided in the 90’s, the tree may precede this date but I cannot prove that. Re: Tree Removal on easement - help 2Feb 21, 2023 7:45 pm Hi I am in a very similar situation with a very large tree on my property that is directly on a sewage easement at the back of our house. This tree was here when we bought the house. Our council is also Kingston. I am wondering what the outcome of this was. Did the council allow you to remove the tree and if so who paid? Thanks You should be able to encase the sewer but you will need it designed and approved and access to lot 580 to do the work 2 17155 You might be able to apply to divert the sewer at your expense. In NSW you would contact a Water services co-ordinator and they would give you advice as to whether or not… 1 16146 Thanks - yea sounds like I need to submit build over easement application....ugh guess I better start finding someone who can do the engineering drawings 3 3360 |
