Browse Forums General Discussion 1 Jul 17, 2021 10:45 pm I’ve been trying for months to get a roofing plumber to install vents for my outdoor range hood and pizza oven. I decided to give it a go today. I didn’t have any dramas except I’m not sure if what I’m seeing will be a problem in future. I used plenty of silicone so excuse the mess. The water is pooling over the flashing and screws. My concern is that over time the water will breakdown the sealant. Should I be worried or does this look ok? It’s been raining all day and no leaks yet. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi there, looking to have a gym in a new build. Planning to install some sort of rubber mat flooring (on concrete) i.e. Asking the builder to not do floorboards in the gym… 0 1607 I know this post is from a while ago, but the VBA has some good guidance on this. https://www.vba.vic.gov.au/__data/asset ... 5-Roof.pdf 2 10808 AFAIK, flashing is a minimum standard. Out of curiosity is your window glass stamped with AS requirements in any of the corners of each pane? Im almost certan if theyre… 2 6315 |
