Browse Forums General Discussion Re: VCAT question - Do you need to go through a lawyer? 2Jul 16, 2021 1:49 pm No, you don't need a lawyer. It's pretty informal. Either side can have a lawyer, but even if they win you don't pay his costs. "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: VCAT question - Do you need to go through a lawyer? 3Jul 16, 2021 8:59 pm jm7821 Do you need to go through a lawyer in order to take your builder to VCAT? Hi jm7821 Nope. Just go to the website of VCAT and apply online. Make sure to check the VCAT site to see whether or not your matter should first be referred to the DBDRV(Domestic Building Dispute Resolution Victoria) prior to filing with the VCAT. Lawyers aren’t actually required for VCAT proceedings. This includes First Directions Hearing and the Final Hearing, if the matter ever reaches that point. However, if you want to manage your risk and get advice then getting a specialist construction lawyer to assist you is probably the way to go. Also, depending on the value of the dispute, your builder would most likely be represented by a lawyer, so you should probably consider being legally represented by one, yourself. Cheers Get sound legal advice. We manage Building Disputes, Construction Contracts, Security of Payment. PM for queries. https://www.contractsspecialist.com.au/articles/ Mofflepop, Are you building around Qld Manly? Building & Legal is a partnership between a construction guy and a construction Lawyer. Construction: we have… 8 26566 Hi When it rains in a particular direction water comes through the security door. It hits the main door and the bottom swells and jams. There is already a cover over the… 0 38793 DIY, Home Maintenance & Repair Are you doing this with a building permit? Conversion of a non habitable room into a habitable room requires building permit. 3 18624 |
