Browse Forums General Discussion Re: What is this white pipe at my backyard? 2Jul 14, 2021 5:33 pm A lot of diagrams for plumbing externally are not always accurate at the pre construction stage, If you have paperwork from Metricon with the plumbing companies details it would be best to contact the Plumbers direct as they always update the plans as to what, where n how the plumbing was done externally yep sounds good make the footing bigger to to allow for the pipe in the middle 3 7326 Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know. 3 4872 I think you are getting different numbers because they all just based them on "other jobs" even though each job is unique. Often, with builders, unless you're speaking to… 3 3240 |
