Browse Forums General Discussion 1 Jul 13, 2021 7:27 pm Hi, Just noticed that on windy days there’s a flapping noise coming through from the externally flumed exhaust fans. Is this normal? Because I don’t remember our rental having any noise. I’m not sure if the noise is from the exhaust fans or whether the noise is just coming through it as that’s where the gap in the ceiling is. Our house has colorbond steel roof, anticon blanket under the roof and r5 batts in the ceilings. Here is a link to hear the noise: https://streamable.com/ipixhc Re: Flapping Noise Coming Through From Exhaust Fans 2Jul 13, 2021 10:53 pm It will be the backflow louvres or flap. They are usually part of the fan and are designed to prevent drafts blowing back down the flue. On a windy day they can sometimes flap a little bit, also happens if you close the door quickly without the fan on. The extra air pumps out the flue and opens the louvres or flap. When the pressure drops they close causing the noise. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Flapping Noise Coming Through From Exhaust Fans 3Jul 13, 2021 11:17 pm Ah so you’re saying this is normal and of no concern? Also it looks like the backflow flaps are inside so even if it is opening and closing, no rain should be able to go in right? Re: Flapping Noise Coming Through From Exhaust Fans 4Jul 13, 2021 11:22 pm Its fine. The flue doesn't get water down it and they are usually part of the fan itself. It's just the difference in air pressure between inside and outside of the house that causes it to flap at times Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Flapping Noise Coming Through From Exhaust Fans 5Jul 14, 2021 12:18 am chippy Its fine. The flue doesn't get water down it and they are usually part of the fan itself. It's just the difference in air pressure between inside and outside of the house that causes it to flap at times Ah I see. Thanks for that Re: Flapping Noise Coming Through From Exhaust Fans 6Jan 12, 2022 8:58 am Yours would be the same as ours as we were through Momu as well, in the end I took of the grill, pulled down the fan removed the screws and took out the damper as it was annoying on windy days. Hi When it rains in a particular direction water comes through the security door. It hits the main door and the bottom swells and jams. There is already a cover over the… 0 38444 My home office is hot with computer equipment running virtually 18 hours a day. When it gets unbearably warm I simply step out of my door into the living area which is… 0 5124 There may be answers here but can't find anything. I have a closed in veranda, four windows. North facing, just had sunblock blinds installed. A bit cooler (actually… 0 2977 |
