VCAT question - Do you need to go through a lawyer?
Do you need to go through a lawyer in order to take your builder to VCAT?
Hi jm7821
Nope. Just go to the website of VCAT and apply online. Make sure to check the VCAT site to see whether or not your matter should first be referred to the DBDRV(Domestic Building Dispute Resolution Victoria) prior to filing with the VCAT.
Lawyers aren’t actually required for VCAT proceedings. This includes First Directions Hearing and the Final Hearing, if the matter ever reaches that point.
However, if you want to manage your risk and get advice then getting a specialist construction lawyer to assist you is probably the way to go. Also, depending on the value of the dispute, your builder would most likely be represented by a lawyer, so you should probably consider being legally represented by one, yourself.
Cheers
9
Mofflepop, Are you building around Qld Manly? Building & Legal is a partnership between a construction guy and a construction Lawyer. Construction: we have…
19/05/2023
3
yep sounds good make the footing bigger to to allow for the pipe in the middle
21/10/2023
Hi When it rains in a particular direction water comes through the security door. It hits the main door and the bottom swells and jams. There is already a cover over the…
