Browse Forums General Discussion 1 Jul 02, 2021 12:31 pm Setting up a home theater in a new double story build. The ceiling on ground floor is completed, as is the flooring on the first floor. In between the cavity space, we need to install a HDMI cable which will run through the beam/joists from one end of the room, to the other (about 8 metres). With the both entries sealed, no manhole or anything, how do gain access the cavity space without breaking into the new ceiling or floor above? Any help or info would be great, thanks. Re: How to access double story cavity space between floors? 2Jul 02, 2021 12:48 pm Unfortunately it should have been installed at the time of all the electrical rough in. You'll be cutting holes in plaster now. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 2 7629 We bought land in Tallawong Schofields NSW size 30m X 12.5m and planning to get double story house build around 350 sqm. We are thinking about having premium inclusions… 0 4154 Old Home Restoration / Renovation To reduce noise transfer without compromising the aesthetic of your exposed I beams, consider filling the 100mm gap between the I beams and the floor above with dense,… 6 9204 |
