Browse Forums General Discussion 1 Jun 27, 2021 9:53 am hi all. wish all is well in this lockdown. I building with Clarendon homes at the initial stage. ground floor ceiling height is 2750mm with internal door at 2340mm. i have requested to increase first floor height at 2600mm , with standard internal door height at 2040mm. i am wondering if this would make it look out of place given first floor height increased from 2450mm to 2600mm. does anyone have a picture showing 2600mm ceiling with internal door height at 2040mm.? thank you Re: ceiling height and door height selection 2Jun 27, 2021 8:44 pm Many display homes I looked at had 2700mm ceilings with 2040mm internal doors. The space above the doors didn’t seem disproportionately high. I would use 2340mm doors if the ceilings were higher though. Unless the room is for storage then it's non compliant BCA V2 2019 S3 P3.8 You have 2 options 1. The builder deconstructs the section and rebuilds as per plan /… 7 10682 i imagine you also have another contract with an architect? and yeah, whatever other's said about special conditions and appendices 16 16000 Hi Kaiser85, We are building with Firstyle Homes. Our build has just started, slab pour is on Saturday (hopefully!). Their standard range is pretty good. We did our… 1 6475 |
