Browse Forums General Discussion 1 Jun 26, 2021 7:54 pm I've got house being built, the land was subject to lsio, hence needed to fill in 600mm, do that finished level with slab meets ahd levels. Now there is 3.5m easement (sewer and Strom water) at back, which is about 900 mm lower from house floor. Q - Can I fill it up to same level say 800mm and rip off the fences and put 800 retaining wall on boundary and put the fence on top of retaining wall? Will council allow to fill in and bring the backyard at same level so that no one falls behind and hurt themself? Have little kids at home... Location : Benalla, VIC Thanks Re: Easement, retainingng wall, fill in 3Jun 27, 2021 10:58 am You will need to check with the council as it may require a planning and Building application (with Engineering) In WA we have a 500mm max so it has to be a variation to the planning codes hth Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Thanks - yea sounds like I need to submit build over easement application....ugh guess I better start finding someone who can do the engineering drawings 3 3386 Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 18168 You should be able to encase the sewer but you will need it designed and approved and access to lot 580 to do the work 2 17168 |
