Browse Forums General Discussion 1 Jun 25, 2021 10:46 pm Re: private stormwater easement enquiry - Would anyone know what easement for support means 0.20 wide, is that the size of pipe that drains the stormwater. I am also trying to determine what internal diameter a pipe (through easement) needs to be to drain stormwater for 2 lots, thanks. 3 m You should be able to encase the sewer but you will need it designed and approved and access to lot 580 to do the work 2 17168 You might be able to apply to divert the sewer at your expense. In NSW you would contact a Water services co-ordinator and they would give you advice as to whether or not… 1 16150 Thanks - yea sounds like I need to submit build over easement application....ugh guess I better start finding someone who can do the engineering drawings 3 3388 |
