Browse Forums General Discussion 1 Jun 18, 2021 5:52 pm Just interested to know what it costs to change a tempering valve on a hot water system. I had one done recently and got charged $380 inclusive if parts, labour and gst. Located in Western Sydney near Wetherill Park. Seemed expensive, anyone know if this is right ? Re: Change tempering valve on hot water system 2Jun 18, 2021 6:40 pm You need to know the brand used to get any sort of an accurate answer but most valves are between $80 to $120 or more. Plumbers also load the price because if something goes wrong with the part, they have to cover it. Did the plumber leave the box behind? You cannot complain about the mark up but you could have asked for an itemised account. Many plumbers have a call out fee and sometimes a minimum time charge for a small job. A call out fee (if charged) and a minimum time charge (usually 1 hour but sometimes more) plus the mark up could easily total $380. You should always get quotes...did you do this? There are some plumbers over on the Whirlpool Home forums, you should also ask on there. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 14368 For our new build in NSW we opted for a heat pump with a 315L storage tank. Early days yet as we only moved in 6 weeks ago. Haven't run out out of hot water though. Ours… 7 3734 Good luck with it. I don't know what the cost of a nice bidet seat with a 25mm air gap will be but you are obviously deducting the cost of a RPZ valve and its… 9 7109 |
