Browse Forums General Discussion 1 Jun 14, 2021 2:48 pm Since we're looking to build, I was thinking of getting a whole of house water filter. Has anyone had experience with them? The main reason is to avoid chlorine and any other impurities in the drinking water (and not worrying about using water out of the Britta jug when cooking). Thanks! if it's the look that you're not happy with, the easiest option would probably be to spray paint it all into the same color as the walls so it blends in. there might not… 3 4504 6 5488 Thanks for the photos. You need to know whether the inflow or the overflow pipe is leaking and this is a simple process of elimination. INFLOW: The vertical riser… 4 5100 |
