Browse Forums General Discussion Re: Land fall - Help please 5Jun 09, 2021 2:22 pm Assuming the contours are at 0.2m intervals (what my last house was surveys at) it looks like around 1m in 45m 400mm difference front to back 300mm side to side. There is some information on understanding survey plans at this link https://anewhouse.com.au/2012/05/unders ... rvey-plan/ The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Land fall - Help please 7Jun 09, 2021 2:41 pm bashworth Assuming the contours are at 0.2m intervals (what my last house was surveys at) it looks like around 1m in 45m 400mm difference front to back 300mm side to side. There is some information on understanding survey plans at this link https://anewhouse.com.au/2012/05/unders ... rvey-plan/ does that make 700mm in total? Re: Land fall - Help please 9Jun 09, 2021 3:36 pm areeba bashworth Assuming the contours are at 0.2m intervals (what my last house was surveys at) it looks like around 1m in 45m 400mm difference front to back 300mm side to side. There is some information on understanding survey plans at this link https://anewhouse.com.au/2012/05/unders ... rvey-plan/ does that make 700mm in total? Yes, corner to corner. . . Assuming they are 0.2m contours. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Thank you Splashers. Tomorrow I might check if I can get a few packs of 300x300 in the same tile finish. It may be good to use these could in the shower recesses. I'm not… 4 4671 I've got a challenge here. Background is the builder has cut too deep for the slab and the slab is now below the very substantial retaining wall. It's failed occupancy… 0 18373 Thankyou so much 😀 I've decided on White on white for doors and trims, White on white 50% on ceiling and Mt buller for walls. Fingers crossed it will look OK 😀 2 7142 |
