Browse Forums General Discussion 1 May 30, 2021 9:24 am Hi all, Could you please let me know if a timber partition wall can be built on existing laminated flooring or the bottom plate should bear on concrete slab directly? Also, can the top plate be connected to the existing suspended Gyprock ceiling or it should be connected to the concrete slab ceiling? Thanks Hi all, Not sure if this is a good place for this question but I guess we'll find out! I'm a novice, building a modular room inside my garage/shed and need to create… 0 1850 Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15887 looks ok to me, round logs retaining walls are better than sleeper walls, more even preservative treatment and stronger since they include the whole tree and not just part… 1 2596 |
