Is there any concern if we choose the metal bondek raw finish?
Does that look cheap work? Should negotiate with builder for any better option?
Any pros/cons?
Whats better option?
Thanks
to do it properly you need to dig out the garden and waterproof the outside of the wall. There are some products you can put on the face of the bricks but the water is…
It sounds like you have a crack in your garage where the wall meets the ceiling, along the shadow line on the…
How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity?
