Browse Forums General Discussion Re: [Syd] Structural Engineering Question - connecting beams 2May 19, 2021 7:19 am world2160 Hi everyone, I've just got structural diagrams for my first floor addition in Sydney. I can see that there are some timber beams in this area of the first floor. (picture below). I have some questions as to how well this is designed. As an example, there is a connection between TB1 and TB1 (circled in the picture). I am assuming they don't "sit" on top of each other because I only have 300mm clearance between the floors. Are they just bolted together like the second picture underneath? If so, how strong is this? I am not criticising the design, but it feels scary knowing there are 12 bolts that hold up the whole floor... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ World2160 That is a really common connection in timber framing, Its super strong so you have nothing to worry about. There are millions of homes in Australia with this type of connection. You will often see that around stair voids where the LVL's need to be connected and those brackets work brilliantly Have a great day Simeon Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Assuming you've modelled the TB8, TB10, TB12, TB2 & J1 joists/LVLs there, it appears as per drawing to me. There maybe should be an additional J1 between TB10 and T12 if… 3 32124 "Losers" "humanity" "off time" "your" "top notch" "love symbol" Sounds like ponzo is done using other people's toilets 36 24463 |
