Browse Forums General Discussion 1 May 05, 2021 3:51 pm Hi all, Hoping you can help with a tricky question on our home reno design. We have a small 2 bed 1 bath villa, that we are renovating to add a 2nd story. Upstairs will include 2 beds, a 2nd living area and a family bath with separate toilet. Downstairs we'll knock through the existing bedrooms to create a large master with walk in robe and ensuite. My question is about the ensuite! Our original drawings had the ensuite as dual access with two doors- one from the walk in robe and another from the living area to create an accessible bathroom down stairs. But we found that the dual access compromised the bathroom layout. Instead we want to shut off access to the living area and this downstairs bathroom and ensuite only and we would expect guest and kids to use the upstairs bathroom. Our builder is horrified and thinks we cant shut the downstairs toilet off!! What do you guys think? Larger, spacious ensuite downstairs and family bathroom upstairs or the accessible downstairs bathroom is most important, even if it means cramming everything into a tiny space. TIA Re: No family downstairs bathroom? 4May 06, 2021 1:27 pm If you don't want to share the ensuite with guests, I would try and squeeze a powder room in somewhere. You may find some space under the stairs to put it in. Hi everyone, Newbie renovator here, after some advice for combining our family room in the picture and the alfresco and make a larger family room. There is a flush sill… 0 4843 Render your bathroom walls, two opinions versus the one, makes you wonder. 3 6023 Hi Geoff Install Puddle Flange prior to any screed. Puddle flange needs to be flush with the surface so you may need to grind away the surface to achieve this. Also as… 2 8323 |
