Browse Forums General Discussion 1 Apr 10, 2021 6:15 pm Hi - I've decided to put a cover over the entrance way to my kitchen. The wall has unbroken 3600 high sheets of 8.5 fibre cement. The corrugated iron sheet butts up against it. Any idea for the best method of flashing this join? I've put a temporary bead of silicon in case of rain. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I know this post is from a while ago, but the VBA has some good guidance on this. https://www.vba.vic.gov.au/__data/asset ... 5-Roof.pdf 2 10628 AFAIK, flashing is a minimum standard. Out of curiosity is your window glass stamped with AS requirements in any of the corners of each pane? Im almost certan if theyre… 2 6278 Building Standards; Getting It Right! There doesn't look to be any rebate in the slab to prevent water from scooting under the window. AS4654 is the Australian standard to look at/refer to. They have… 1 10160 |
